Home > Forums > Software User Forums > FLOW-3D
Meshing & Geometry - issue with inner hollow tube rendering
Old   January 29, 2012, 17:59
Question Meshing & Geometry - issue with inner hollow tube rendering
kavanaa1 is on a distinguished road
Hi All,
I have a mould that contains a hollow ceramic tube inside into which metal fills from a funnel. When the metal exits the bottom of the tube it hits the bottom of the mould before reversing direction and filling up some cavities/castings attached to the mould wall. When I set the mould and funnel as a hole inside a solid cube and the ceramic tube as a solid in a separate component, the bottom of the funnel goes missing and the metal just spills into the mould, not via the ceramic tube. I've attached an image I hope explains the issue a bit more.
Can anyone suggest how I can achieve the metal filling the mould via the ceramic tube by being connected to the funnel.
Thanks a lot
File Type: jpg Funnel Geometry Flow3D Rendering Issue.JPG (62.3 KB, 35 views)
kavanaa1 is offline   Reply With Quote
Old   November 27, 2012, 16:02
MC
melissa is on a distinguished road
So the geometry is all boolean based-
So if you have a solid and subtract is will subtract that entire geometry from the solid.
Here is my suggestion:
Subtract the tube from solid mold along with cavity and overflows
Then as a new component add the tube back in.
melissa is offline   Reply With Quote
[ICEM] Meshing of 3d flywing geometry sfs ANSYS Meshing & Geometry 24 November 17, 2011 04:49
[ICEM] Meshing on a Complicated Geometry tav98f ANSYS Meshing & Geometry 2 August 17, 2011 11:15
[ANSYS Meshing] Help - Meshing 2 Surfaces On A 2D Geometry Ali_M ANSYS Meshing & Geometry 4 March 29, 2011 03:01
[ICEM] Icem Geometry creation strategy for hollow cube tony00 ANSYS Meshing & Geometry 1 March 16, 2011 11:05
Simple Frustrating Meshing Issue in Gambit (w/pics) Dylan ANSYS Meshing & Geometry 6 March 23, 2009 16:14
