August 9, 2012, 13:54 |
pressure iterations not converging
Vikram Reddy
Rep Power: 13 |
Hello everyone, I am trying to model a reactor and I am having a few difficulties in doing so. The pressure iterations are not converging ( I tried setting max iterations to 5000, GMRES etc).
Are there any strategies to make it converge? Please help. Thanks in advance, Vikram |
August 13, 2012, 19:10 |
Rep Power: 13 |
Well, there are a lot of things that you can try... Check the troubleshooting section of the manual for suggestions. My recommendations:
1. Check that the initial and boundary conditions are reasonable and match reality. 2. Check any STL files for problems 3. Check your mesh. Cell aspect ratios should be less than ~3:1; ideally closer to 1:1. The cell size should not change by more than a factor of two between multi-block meshes and the grid lines should align. 4. Check that epsi/epsadj are reasonable 5. Try adding some fluid compressibility (rcsql/rcsqv) 6. Reduce the time step size 7. Increase GMRES subspace size (mrstrt) 8. Try SOR with omega<1 and itmax ~5000 As a side note, using itmax=5000 with GMRES usually doesn't work well. If the problem doesn't converge with the default settings it is usually an indicator of some other problem. |
August 13, 2012, 19:13 |
Vikram Reddy
Rep Power: 13 |
Thank you very.
I figured it out, the problem was with my initial conditions. Thanks again Mr. dmilano |
Display Modes | |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 07:54 |
Interfoam blows on parallel run | danvica | OpenFOAM Running, Solving & CFD | 16 | December 22, 2012 03:09 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 13:30 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 01:36 |
