Home > Forums > Software User Forums > FLOW-3D
FLOW3D model spontaneously explodes
Old   March 25, 2013, 11:24
Default FLOW3D model spontaneously explodes
Simon
Roark is on a distinguished road
My FLOW3D model spontaneously became unstable after happily chugging away for 2 days. Analysis of flow fields prior to the explosion showed nothing amiss. I was solving for the long-term mixing resulting from a quasi-steady-state jet injecting fluid into a stratified reservoir. The velocity field developed within the first 10% of the model, and the remaining simulation is to capture the gradual temperature mixing. Thus, I am perplexed why the model suddenly became unstable.
My question is: Are there any important tips/tricks I should use to avoid spontaneous instabilities? And if the solution becomes unstable and blows up, are there any important tips/tricks for diagnosing/fixing the model?
Thanks!
(For reference, here are my solver settings... Pressure: Implicit, GMRES. Viscous Stress: Explicit. Heat transferL Explicit. Advection: Explicit. Momentum: 1st Order. Turbulence: RNG)
Roark is offline   Reply With Quote
Old   March 25, 2013, 13:06
dmilano is on a distinguished road
One thing to watch for is the size of the maximum residual from the implicit pressure solver. The convergence criterion for this solver is [usually] inversely proportional to the time step size, so if the time step drops the convergence criterion can become large. If it remains large for too long it will yield a poorly converged solution.
Check if there is a sudden increase in the maximum residual near the time that the results become unreasonable. If so, try reducing the convergence criterion multiplier (epsadj) or changing to a constant convergence criterion (epsi).
dmilano is offline   Reply With Quote
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
Ocean Wave Model with FLOW3D Haryo Armono Main CFD Forum 0 January 28, 1999 13:11
