Home > Forums > Software User Forums > FLOW-3D
Volume source rate
Old   November 2, 2012, 13:20
Question Volume source rate
max
max0014 is on a distinguished road
I have a simple plot setting with sloping surface for Shallow water modeling. The 4 faces (x-min, x-max, y-min, z-min) are set wall boundary and upper (z-max) is set pressure boundary and y-max is set outflow boundary. I want to apply volume source rate uniformly (rainfall) only to open upper boundary. But it seems FLOW-3D accounts outflow boundary into open boundary too. How can I apply volume source rate uniformly only to upper boundary which is sloping surface?
Thank you,
max0014 is offline   Reply With Quote
outflow boundary, shallow water equations, sloping surface, source rainfall
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
how to calculate the reversed volume flow rate in an certain iso-surface? coolliuyinli FLUENT 2 September 4, 2012 01:33
Please check out my parallelized udf code aleisia Fluent UDF and Scheme Programming 0 June 10, 2011 16:16
URGENT: How to set fixed volume rate in a air volume? SolarX FLUENT 1 September 17, 2010 10:25
average volume flow rate carno FLUENT 0 April 12, 2007 06:37
