August 10, 2013, 15:19 |
Sediment Scour Depth and Sediment Hight
hossein
I am using Flow-3d V9.3.2 for simulating scour around cylinder. How can I measure sediment height and Max. scour depth at this version of flow-3d ?
I really need your prompt help. Thank |
August 19, 2013, 08:01 |
Zeregaber Moghes
Rep Power: 12 |
I guess you can get the results from the iso-surface in 3D output or from the text output as "Packed sediment height" or "Packed sediment net height change".
December 31, 2015, 02:47 |
Hi Hossein
Ramin
you can send the output file in JPG format to the Autocad, then by scaling the dimensions, you can measure the scour depth with high accuracy
flow-3d, flow3d, scour, sediment, sediment concentration |
sediment scour | pyxbird | FLOW-3D | 27 | March 5, 2016 13:38 |
sediment scour | mahdi1 | FLOW-3D | 0 | April 23, 2013 18:11 |
