November 21, 2013, 03:35 |
how to show the units on the results.
ouni firas
Rep Power: 12 |
how to show the units on the schemas results. I has used> Analysis> 3D> Units> Plotting Units> SI. and I check> Show units on studs, but the results are shown without UNITs, I have not found an explanation?
November 24, 2013, 16:07 |
Jeff Burnham
Rep Power: 17 |
You need to set the unit system on the Model Setup > General tab before you run the simulation. Only then can does the output file contain info about what the original units are so that they can be converted or shown on output plots. Otherwise what you did is correct.
Problem: Very long "write" time (~2h-3h) for results and transient results | Shawn_A | CFX | 16 | April 12, 2016 20:49 |
Lost Scenario Results..?? | Fugacity | Autodesk Simulation CFD | 1 | February 24, 2012 10:48 |
[OpenFOAM] ParaFOAM 3Dwindow doesnbt show results continuously | dresi | ParaView | 1 | February 19, 2009 23:19 |
Circular miniFlume experimental amp numerical results | amelia | OpenFOAM Running, Solving & CFD | 11 | September 4, 2005 22:42 |
To dimensionalize or not to dimensionalize !! | tolani owosina | Main CFD Forum | 8 | November 13, 1999 13:45 |
