Home > Forums > Software User Forums > FLOW-3D
Fluid Height
Like Tree1Likes
  • 1 Post By JBurnham
Old   February 24, 2014, 20:47
Default Fluid Height
tsung han yang
robin781105 is on a distinguished road
Dear expert:
I try to set the "Volume flow rate" boundary, so there needs to set both "Volume flow rate" and "Fluid Height".
There's a question, how can I set the "Fluid Height" when I fix the "flow rate" ?
How to know the true "normal flow depth" ?
robin781105 is offline   Reply With Quote
Old   February 28, 2014, 19:32
Jeff Burnham
JBurnham is on a distinguished road
You have to hand-calculate it, or know it from field data. The variable you must input is the water surface elevation (distance from the z = 0 plane), not depth.
spaudel likes this.
JBurnham is offline   Reply With Quote
Old   March 2, 2014, 10:21
tsung han yang
Thanks JBurnham
It means I need to use Manning's equation to calculate the fluid depth?
Or Flow-3D has it's own equation to calculate fluid depth?
Old   March 12, 2014, 21:03
Jeff Burnham
You need to know what the depth is at the boundaries. If this is an imaginary situation, then use Manning's. If it's real, then use field data. FLOW-3D can't do it for you because Manning's requires modeling all the way from the nearest critical control. That might be many kilometers! If necessary, use HEC-RAS to estimate the steady-state depths of the boundaries.
Old   March 18, 2014, 22:10
tsung han yang
Thanks JBurnham!
I don't have the real data.
Is it feasible to determine the flow depth first then choose the water status to determine the discharge inflow?
y => Fr => Q=AV => get Q?
P.S.I'm a master student from Taiwan, my research is about weir flow.
If it possible, can I get your email and discuss with you?
ansys cfx solver exit with return code 1!!!!! mhabibnia CFX 7 August 19, 2013 03:53
Questions of fluid pairs fjalil CFX 1 June 10, 2009 17:36
Fluid pairs fjalil Main CFD Forum 0 June 10, 2009 13:47
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
