Home > Forums > Software User Forums > FLOW-3D
boundary condition between mesh blocks
Like Tree2Likes
  • 1 Post By JBurnham
Old   April 26, 2014, 10:46
Default boundary condition between mesh blocks
boesendorfer is on a distinguished road
What's the use of boundary condition in the intersection of two mesh blocks?
If the fluid can pass through it freely, which BC type should I choose?
boesendorfer is offline   Reply With Quote
Old   April 28, 2014, 03:59
Maxime
macsim is on a distinguished road
You should use symmetry BC (this is the default BC).
macsim is offline   Reply With Quote
Old   April 28, 2014, 14:09
Jeff Burnham
JBurnham is on a distinguished road
FLOW-3D resets the boundary condition between blocks automatically to "inter-block" type. You can't set this yourself, FLOW-3D does it for you. Using 'symmetry' prevents some warning messages about resetting the condition.
Serhan Aldogan likes this.
JBurnham is offline   Reply With Quote
Old   April 28, 2014, 21:30
johnsonw is on a distinguished road
I wonder if you could tell me what the meaning of BC Grid Overlay
johnsonw is offline   Reply With Quote
Old   April 29, 2014, 08:04
thank you all. Maybe I haven't read the manual carefully enough
Old   April 29, 2014, 11:09
Jeff Burnham
Grid Overlay boundaries are only used in Restart simulations. They interpolate velocity from an existing simulation results. You can use them to change the mesh but still continue from the old simulation results.
boundary condition
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Correct velocity boundary condition for a wall in a rotating mesh zordiack OpenFOAM Running, Solving & CFD 2 March 4, 2014 10:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Framework for moving mesh based on 2D-computation as a boundary condition Arnoldinho OpenFOAM Running, Solving & CFD 0 May 17, 2011 12:48
