January 3, 2014, 06:49 |
turbulance parameter
razieh anari
Rep Power: 12 |
Hi
1- what is the mean of pressure in flow 3d? dynamic or static? 2- what is the mean of turbulent energy? is the same kinetic energy of turbulence? k=0.5(u'2+v'2+w'2) u', v', w' are Average volatility. thanks a lot . |
January 3, 2014, 12:57 |
Jeff Burnham
Rep Power: 17 |
1) p = static pressure.
2) turbulent energy = turbulent kinetic energy, TKE, just as you have guessed: k = 0.5(u'^2+v'^2+w'^2). TKE has units of L^2/t^2 (J/kg in SI). On the Simulation Manager tab (and in Analyze > Probe > General History Data) there is an output called "mass-averaged turbulent energy": MTKE = sum(k*mass)/sum(mass). In FLOW-3D variables, MTKE = sum(k*rho*f*vf*del)/sum(rho*f*vf*del). Rho is local fluid density, f is local fluid fraction (volume fluid in cell/open volume in cell), and vf is local volume fraction (open volume in cell/total volume in cell), and del is the cell volume dx*dy*dz. The term rho*f*vf*del = mass of fluid in cell. |
April 26, 2014, 14:30 |
turbulent dissipation
razieh anari
Rep Power: 12 |
hello, thank you for your answers:
please tell me, what is the differences between turbulent energy and turbulent dissipation? turbulent dissipation is reynolds stresses?if not, what's its formula? i need u' , v' , w' , can i have these from out put result? |
July 13, 2014, 06:40 |
#4 | |
mh
Rep Power: 11 |
(i need u' , v' , w' , can i have these from out put result?) can you solve this problem? |
July 14, 2014, 11:00 |
Jeff Burnham
Rep Power: 17 |
You can get u', v', w' from LES turbulence modeling. You can't get the velocity fluctuation components separately from RANS turbulence (like k-e or k-w).
July 14, 2014, 17:11 |
mh
Rep Power: 11 |
July 18, 2014, 13:17 |
Jeff Burnham
Rep Power: 17 |
Use FlowSight (the new post-processor that comes with v11). It can calculate the time-mean velocity values u_, v_, w_ in all cells over a steady-state flow. Then have FlowSight perform an arithmetic operation to subtract: u, v, w - u_, v_, w_ = u', v', w'. From the new fluctuation variables, you can find the max/min, 95th percentile, etc.
calculating output parameter in cfd post | markus67 | CFX | 3 | August 26, 2015 09:28 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Error when input new parameter in Fluent | micro11sl | FLUENT | 0 | July 1, 2011 06:42 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
Expert Parameter for compressible transient | ioannis | CFX | 0 | November 2, 2005 19:28 |
