December 9, 2014, 17:10 |
How to express strain rate in Comsol
hassan
Rep Power: 11 |
Hello everyone,
I am relatively new to simulation. I have a question in COMSOL but it is quite general. I am trying to define an analytic function in COMSOL. The equaiton is Carrea_Yasuda fluid model. It is non newtonian fluid model that is function of shear rate. How to write an expression for the shear rate for a 3D problem? Thank you very much for your help. Best regads, hasan. |
December 10, 2014, 11:34 |
Jeff Burnham
Strain rate and shear rate are tensors, and that's how they're solved in 3-D. The lab data you fit to parameterize non-Newtonian models are usually from a testing apparatus that is essentially 1-D, so the tensor has a lot of zeros and can be represented as a single scalar value. That shouldn't stop you from being able to parameterize the fluid; you don't need to know the 3-D characteristics of the flow, you just need to know the lab data.
This is a FLOW-3D forum, not a Comsol forum, so you're not likely to get an answer here that's more detailed than that. |
strain rate in UDF | Paulina | FLUENT | 11 | November 20, 2014 03:06 |
shear rate and strain rate | Lilly | FLUENT | 1 | August 29, 2014 00:46 |
Shear Strain Rate | Dave442 | Main CFD Forum | 5 | October 25, 2013 04:08 |
strain rate magnitude | ahmadbakri | STAR-CCM+ | 1 | June 3, 2010 13:03 |
strain rate at arbitrary position in a cell | K. Kevala | FLUENT | 0 | February 4, 2004 17:14 |
