February 21, 2016, 18:37 |
New Computer for Flow 3D
Ontario
Rep Power: 10 |
Good day i have a quick question.
i was Given a server with duel 6 core Xeon processors and 32gigs of ram. after i installed flow3d i noticed that it was only using one of the processors. i'm just running flow3d 11.0.4.5. if its possible to use both processors on one computer that would be great for any advise if it will work or not. Cheers, Ian Dunlop |
February 22, 2016, 20:04 |
Ontario
Rep Power: 10 |
So after running some simulations the solver says its using all 24 processors but when i do a resource check on the server it only using one processor so only 6 cores ie 12 processors.
any ideas thanks guys ian |
April 4, 2016, 16:10 |
Ontario
Rep Power: 10 |
thanks for getting back to me here are some screen shots, capture is the resource manager, capture 2 is the initial setup to say use all cores,
if u have any questions let e know thanks Ian Dunlop |
April 4, 2016, 16:20 |
Ontario
Rep Power: 10 |
Thanks for getting back to me so quick, and sorry i didn't know i clipped the image.
cheers Ian |
April 4, 2016, 16:34 |
Your computer specification is "Duel core with 6 processors", which means you only have 2*6=12 physical cores. Rest of the cores that you see on resource manager are hyper-threads originating from the system architecture itself.
Therefore, you should ideally be using 12 cores only. Now, FLOW-3D detects 24 cores because hyper-threading is on, on your system. |
April 4, 2016, 16:38 |
Ontario
Rep Power: 10 |
thanks thunde47, for all the help
Cheers Ian |
April 4, 2016, 16:39 |
#9 |
You can either be specific and use only 12 cores on FLOW-3D, or you can de-activate hyperthreading following online resources based on your operating system such as http://www.pcmag.com/article2/0,2817,2422874,00.asp
I wont bother because at least 12 cores are getting used anyways, so there is still 100% utilization of computational power. |
[OpenFOAM] Error with using of pvbatch on Super Computer | shipman | ParaView | 5 | November 18, 2015 04:56 |
Recommended computer for OpenFOAM simulations | janepen | OpenFOAM | 2 | October 29, 2012 01:44 |
Running OpenFoam on a Computer Cluster in the Cloud - cloudnumbers.com | Markus Schmidberger | OpenFOAM Announcements from Other Sources | 0 | July 26, 2011 08:18 |
Open ANSYS12.0 Workbench Project on another computer | Andrew | FLUENT | 2 | July 6, 2010 00:20 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 11:20 |
