Home > Forums > Software User Forums > FLOW-3D
Loosing Volume, High Simulation Time and Problem About stl File
Old   March 2, 2016, 05:46
Default Loosing Volume, High Simulation Time and Problem About stl File
thetitans is on a distinguished road
As a beginner in numerical modelling,i have some problem with my model.First of all, i am modelling an experiment area and our discharge will be very low. I put a bathymetry in model. The mesh boundaries are xmin: volume flow rate xmax: outflow (also tried continuative and pressure(with elevation))
1. Loosing volume:
With this boundary condition i am loosing volume of water regularly. With a pressure boundary condition volume became stable but this time it reflect the water..
2. I have 100000 grid, for 550 sec. simulation it takes 3 hours is it normal?Also is 550 sec simulation too short for my simulation.
3. Lastly, i have 3 dimensional drawing (3dm rhyno file) and i convert it to stl format but the problem is this file became 2.6 gb so i can not use it for my purpose.
Thanks for your help
Notes: Flow 3d v.10.1.1.05 solver
Picture one what i have, picture 2 what i want to have
thetitans is offline   Reply With Quote
Old   April 4, 2016, 15:52
thunde47
thunde47 is on a distinguished road
1. In the latest version of FLOW-3D (11.1 onwards) there is a wave absorbing component feature that will not reflect waves.
2. Simulation time is often dependent on the number of cores you have. Depends how many of those you are using.
3. Why cant you use the converted file?
thunde47 is offline   Reply With Quote
Old   April 21, 2016, 07:49
Thanks a lot, actually i have lost my hope about this topic. I solved the sol problem, i draw in Autocad from beginning. For the other options i will try to get new version of flow 3d. The number of cores are 2 (4 with imaginary) i7 3.8 ghz with boosting..
Thanks a lot
Old   December 1, 2016, 06:36
lixinwei
lixinwei1993 is on a distinguished road
hello, I have the same problem of losing volume when I simulate the laser welding process. Did you solve this problem?
lixinwei1993 is offline   Reply With Quote
boundary condition, flow3d, simulation time, volume flow rate
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
