help with spur dike
3 Attachment(s)
i want to model a spur dike
but i faced some problem 1) scour happened at first of channel when the material change from solid to sediment, how can i define my problem to avoid these scours??? 2) scour happened at the place where mesh boxes joins!!! how can i avoid this problem?? 3) my flow depth should be 15 cm ,but after a long time running the model flow depth became 10cm :| and i don't know what to do i attached my model to the post and the result after 160s and flow depth if anyone have any idea or suggestion i would be very thankful Regards, Hanif |
