FlowSight - Compare Cases
I have two cases/scenarios with minor geometry differences. I'd like to do a comparison of let's say velocities between the two. Is it possible in FlowSight. In other words, how can I use the Calculator to calculate something using variables from different cases. As I said, the domain is pretty much identical. You can only link cases if they are sequential in time; i.e. if there is at least one time step in common between them. Cheers |
