How setting mesh to get symmetrical fill on a symmetric cad geometry |
September 4, 2017, 03:55 |
Rep Power: 9 |
Dear all,
i meet a very hard problem on HPDC, high pressure die casting, simulation in FLOW3D. The part cad is symmetrical with ingate and fluid is push by piston in sleeve. However, the filling pattern is not symmetrical. i set run cases with different mesh planes/cell size (FAVOR are all good). such as: case 1: along Z direction. mesh plane 1,.....10, case 2: along Z direction. mesh plane 1,.....8, The filling results of case 1 and 2 are different. mesh is not robust in F3D. could anyone has the sulotuion? |
September 4, 2017, 04:01 |
Rep Power: 9 |
other settings are all same, just mesh different.
[snappyHexMesh] not symmetric mesh around symmetric geometry | Aeronautics El. K. | OpenFOAM Meshing & Mesh Conversion | 1 | May 23, 2020 02:51 |
Fill CAD Geometry | voldemort | Autodesk Simulation CFD | 0 | July 12, 2016 01:47 |
[ANSYS Meshing] orientable surface mesh - CAD error | powpawell | ANSYS Meshing & Geometry | 0 | April 1, 2015 01:15 |
[mesh manipulation] Split a ready mesh for a symmetric geometry | Artur | OpenFOAM Meshing & Mesh Conversion | 0 | June 11, 2013 16:44 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
