Home > Forums > Software User Forums > FLOW-3D
how to check solid weight
Like Tree1Likes
  • 1 Post By thunde47
Old   June 19, 2017, 11:13
Default how to check solid weight
tonny
tonnymiked@gmail.com is on a distinguished road
hi,
I have few question need your help?
1. Can you please show me how to check solid weight in flow 3D after insert mass density?
2. Do you have manual on how to key in moment of inertia in flow 3D?
Hope to hear from you as soon as possible. thanks for your help.
tonnymiked@gmail.com is offline   Reply With Quote
Old   June 22, 2017, 17:48
thunde47
thunde47 is on a distinguished road
Hi -
To find the object mass, it is usually easiest to set the material density and then preprocess your simulation. The mass can be found in the .prpgrf file based on component number.
Similarly, if you are looking to compute the object moment of inertia, you can find relevant values within the .prpgrf file as well (this will be in the simulation directory). You can tweak the moments of inertia as necessary based on your requirements thereafter.
thunde47 is offline   Reply With Quote
Old   July 18, 2017, 07:37
tonny
hi,
thanks for your help, but i couldnt find the .prpgrf file in my working folder. Any idea where i can get those file?
Old   July 18, 2017, 10:30
thunde47
prpgf is generated when you just preprocess the simulation. Right click on the simulation and instead of Run Simulation, click Run preprocessor.
M.Nazrin likes this.
Old   July 20, 2017, 21:57
nazrin
M.Nazrin is on a distinguished road
Hello, where can i find those value? is it under analyze tab? can you guide me to those parameters (mass, center gravity, mass inertia tensor)?
M.Nazrin is offline   Reply With Quote
Old   July 24, 2017, 12:22
thunde47
Here is the step by step process:
1. Go the simulation folder where all the files are located.
2. Open prpout.<prepin extension> file in notepad++ or some editor of your choice.
3. Search for the word "inertia".
You will find the mass, volume, moment of inertia tensor in there. Please check the image below.
Old   July 24, 2017, 19:12
nazrin
tq for the reply sir. SO the value was given in the inertia matrix form right? tqvm!!!
properties of solid mixture Ahmed Khattab OpenFOAM 0 December 26, 2012 13:59
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 07:14
Molecular weight of the solid phase? imburse CFX 3 May 9, 2002 18:28
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
How to calculate density of solid phase zhou Main CFD Forum 0 December 17, 1999 19:06
