How to validate a 3D poiseuille flow in a rectangular channel? |
February 24, 2017, 07:30 |
I am not sure if i should validate my 3D poieuille code with an analytic 3D formula for the velocity profile (which seems a little bit complicated), or just plot the velocity profiles in the middle plane of the channel (symmetry plane) and see if it is similar to the 2D case? Please help ! |
August 30, 2017, 11:06 |
Katt
Rep Power: 8 |
Did you find any analytic solution for the 3D velocity expression in a rectangular channel. I do know that for a circular channel maximum velocity is 2 times average velocity and for rectangular channels it is 1.5 times the average velocity.. Any help with a 3D expression? I roughly get the co-efficient as 2.1 but is not consistent. I guess it is also dependent on the channel size. |
channel flow, poiseuille, rectangular, validation |
Validation for a channel flow code | jinhua2015 | Main CFD Forum | 7 | December 31, 2015 12:03 |
Open Channel Flow | ElanMorin | FLUENT | 4 | February 25, 2015 16:26 |
simulate cross section of 3D fully Devolped poiseuille rectangular closed channel | amin144 | OpenFOAM | 6 | July 4, 2012 03:54 |
Modeling the mixing of air and kerosene in a flow channel | StefanG | CFX | 3 | June 11, 2012 20:21 |
compressible channel flow.. | R.D.Prabhu | Main CFD Forum | 0 | July 17, 1998 17:23 |
