March 31, 2017, 03:41 |
cavitation in Flow-3D
Kazem Dalili
hi everybody
i want to calculate the cavitation index (sigma) in a chute. should i use 'cavitaion' section in physics? if yes, so which part shoul i use between 'cavitation model' & 'cavitaion potential model'? and what is the amount of cavitation pressure? |
April 13, 2019, 16:58 |
Ysmn
Rep Power: 8 |
Hi, could you find any solution?
Thanks, Yasemin |
April 14, 2019, 12:04 |
Kazem Dalili
I tested both two ways, and the results did not differ
April 19, 2019, 10:43 |
zohran arif
Rep Power: 8 |
i did without the cavitation model. In a low level outlet modeling i used the Absolute pressure values and velocity obtained by Flow-3d and applied the formula
Pabs - Pvap / 0.5*density*v^2 |
Exit Corrected Mass Flow Rate Mesh Sensitivity Study | s__s__s | CFX | 4 | July 20, 2016 11:46 |
Two phase flow (Nozzle cavitation model) problem | lehoanganh07 | FLUENT | 10 | December 15, 2013 10:23 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Any one have tutorial for cavitation flow over hyd | Md.Nur-E-Mostafa | FLUENT | 1 | March 11, 2009 00:02 |
Kármán vortex street in cavitating flow behind bodies in the cavitation tunnel | L. Könözsy | Main CFD Forum | 0 | April 17, 2000 13:16 |
