October 15, 2019, 02:49 |
General Moving
farhan
Hello, I've problem in set up model for moving object,Where can i solve this problem to ensure my object moving according to my set up
November 19, 2019, 11:38 |
You can either prescribe the motion in the moving objects model or dynamically couple the motion with the fluid. To know more about the model please check our documentation in the Help menu.
November 20, 2019, 22:11 |
#3 | |
Ebrahim Hamid
Rep Power: 7 |
I am simulating moving objects in flow 3d but I have problem in how to define the friction coefficient between 2 objects. For example The friction between tires and surface. The problem when the water start to the object drag with very low flow depth and velocity. Thanks |
Question on moving mesh, mesh velocity is really small! | ripperjack | Main CFD Forum | 2 | April 28, 2014 13:37 |
2D selective mesh generation | Durga Sravan | ANSYS | 17 | February 5, 2014 00:56 |
Moving boundary destroy other internal meshing | yhaomin2007 | OpenFOAM | 1 | November 7, 2013 02:34 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
How to make boundary layer mesh moving with wall | wayne | FLUENT | 3 | June 11, 2008 23:23 |
