March 2, 2009, 20:21 |
How did I set two kind of slope in channel ?
Dear Experts :
If I want to set a slope in channel. I can set gravity component in the X-direction. But I will set two kind of slope now. Besides uses Auto CAD to construct the slope. Did there have any methods to solve? Another question. If I construct a Geometric model. On side wall's boundary condition whether to need to set "wall boundary"? Thanks your help! |
March 3, 2009, 18:15 |
Re: How did I set two kind of slope in channel ?
What do you mean you will have two slopes? Will they be in different directions or just different parts of the geometry?
The main difference between a wall and a symmetry boundary is there is no friction at the symmetry boundary. So if you have heat applied to the wall or if you are interested in viscous stress along the wall then you would use the wall boundary. |
March 3, 2009, 20:45 |
Thanks MC~
Yes, I mean that have a channel but there have two kind of slopes(that is upstream slope is 1 degree downstream slope is 5 degree). How did I set two kind of slopes, I don't want to use Auto CAD to draw slopes of channel. Thanks your help! |
March 4, 2009, 10:37 |
I think either way you will have to use AutoCAD unless your channel is simple geometry then you could create it in FLOW-3D and rotate it to the angled slope.
March 5, 2009, 04:25 |
Very thanks your help, MC.
March 5, 2009, 06:21 |
There is another problem with slope channel - mesh roughness (as we call it). If you rotate your channel in AutoCAD you will get roughness due to vertical orthogonal cubic mesh. That is the problem. I used component of gravity.
Regards. |
March 4, 2022, 12:32 |
#7 | |
Hariom Gautam
March 15, 2022, 00:10 |
#9 |
Sehroosh
Rep Power: 6 |
In Flow 3D, geometry file is one of the main inputs. Remember
TEL = z + h + v2/2g 'z' comes from geometry. Once 'z' is disturbed, results will be incorrect no matter how realistic they look. |
August 30, 2022, 08:07 |
#10 |
UK
Rep Power: 6 |
Remember that for initialisation by elevation, it will be applied in the Z direction (in case you change the gravity vector to something else).
about open channel simulation in flow-3 | Marco | FLOW-3D | 4 | January 11, 2013 11:53 |
How to set inflow mach in a transonic channel? | Johnson | FLUENT | 1 | May 7, 2011 03:24 |
About Cooling channel | alefem | FLOW-3D | 1 | May 28, 2010 11:15 |
Installation problems | indy | OpenFOAM Installation | 7 | April 3, 2009 09:40 |
Problems with installation | jonititan | OpenFOAM Installation | 4 | November 6, 2005 04:16 |
