Couple two launch results
Hi everybody,
Do you know if it's possible to couple two launch results, an initial from 0 to 80s, and a restart from 70 to 200s ? FLOW 3D v11 |
Just follow these steps:
i) Select first result file say "Main". Set your desired outputs and time frame. Check Option 'Render frames to disk', then RENDER ii) Now open 2nd result file say "Restart". Again set your desired outputs and time frame. Check Options 'Render frames to disk' & 'Append to existing output". A dialog box will open. Go to the folder where you rendered the file "Main". iii) When asked select "Overwrite All Files". Press RENDER. Now you have results from both files in Display and shall play in sequence. |
