how to solve convective flux exceeded stability limit? |
Gang Xi
Rep Power: 2 ![]() |
I am simulating the additive manufacturing by a laser. the beam source is added in qsadd.f in which I modified rhoe. But the simulation is always show "convective flux exceeded stability limit". And my max fuild temperature is up to 60,000, min fuid temperature is down to 0. I try to Modify the numerics options, it doesn't work. How can I solve it? anyone can help me?
Rep Power: 12 ![]() |
Did you try to reduce the max time step
Gang Xi
Thank you for your answer. I try it, but it doesn't work. And I find that it can run if I ignore this problem, and this tip will disappear when the calculations settle down. It just appear in the first. Is that because the great chage of the fluid?
Display Modes | |
Convective term with extra coefficient in Flux | onlyacan | OpenFOAM Programming & Development | 1 | August 18, 2016 12:05 |
Can we solve only convective and source term | Mehdi | Main CFD Forum | 1 | February 17, 2004 23:40 |
convective heat flux | zhujg | Phoenics | 1 | December 11, 2003 16:41 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
the calculation of convective flux | Hai-Wen Ge | Main CFD Forum | 14 | April 23, 2001 06:34 |
