How to Set Flow Boundaries for Simulating River Confluence with a Sloped Inlet |
Guangxi University
Rep Power: 2 ![]() |
I am conducting a simulation of river confluence with a sloped inlet where the main stream inlet is not perpendicular to the mesh boundary and forms an angle. Given the main stream flow rate but unknown inlet velocity, how can I set boundary conditions to allow water to flow diagonally into the main stream inlet?
Akhmad Iqbal Ikromi
Rep Power: 0 ![]() |
Hi, I think you need to simulate the case (only upstream) using 2D to know the velocity magnitude, then you can use the result to feed in your 3d model boundary condition.
Guangxi University
Thank you very much for your answer. I also want to know how to make the flow rate flow obliquely into the tributary when setting the flow rate, just in the direction of the red arrow in the sketch.
Display Modes | |
Using gnuplot to plot probe data | Rotidpor | OpenFOAM | 3 | March 9, 2022 05:44 |
how to set inlet and outlet BC for oscillatory flow around a circular cylinder | November | OpenFOAM Pre-Processing | 2 | June 2, 2020 09:08 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
mass flow inlet | Denis Tschumperle | FLUENT | 7 | August 9, 2000 02:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
