[Sponsors] | |||||
Akhmad Iqbal Ikromi
Rep Power: 0 ![]() |
Hi, I just run a case of simulation with 3600 s simulation time. Due to some problem to my computer, I need to restart the simulation, so currently I have 4 separate files. 0-100s,100-400s, 400-1000s, 1000-3600s.
I have combined these 4 data into 1 merge .flsgrf file using FLSGRF editor (grfedit.exe), but it seems something error when I was opening the combined file. My question is: 1. My results got many .flsgrf files, e.g. flsrgrf1.filename, flsrgrf2.filename, flsrgrf3.filename ~ flsrgrf13.filename, do I need to compile each flsgrf file? or only by flsrgf1.filename, because when I open the post processing it only appears flsgrf1.filename to be opened 2. Is the any function to merge the Exodus II file? since all of my simulations had set the output both flsgrf file and Exodus II file. 3. Is there any function to present the result animation in Flow3D post without merging the file first? However, I need to add the discharge hydrograph along the simulation time (1-3600 s in one animation) Thanks all!! |
| Tags |
| animation, exodus, exodusii, flsgrf, merge |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [General] Exporting Exodus database file with sidesets | mahdialloush | ParaView | 0 | June 29, 2024 04:42 |
| Create Exodus mesh from AirfoilMesh script | kilojoules | Pointwise & Gridgen | 2 | November 17, 2017 15:48 |
| [General] Building Paraview 4.1.0 with MPI and Python support | reynoldsStress | ParaView | 10 | July 27, 2017 09:38 |
