Home > Forums > Software User Forums > FLOW-3D
How to Visualize Surface Force Output in Flow3D (v11.0.4)?
Old   May 12, 2025, 15:15
Question How to Visualize Surface Force Output in Flow3D (v11.0.4)?
Mahmood
Mahmood1986 is on a distinguished road
I am trying to visualize the total force (pressure and shear) acting on a surface in Flow3D (v11.0.4). I enabled the Pressure and Shear Force Output option in the Component Properties > Output tab and specified the surface coordinates (X, Y, Z). However, after completing the simulation, I cannot locate the force results for the surface in the output.
As a workaround, I defined a baffle and calculated the force on it using Results > Probe, which worked. However, I want to use the first method (via Component Properties) directly. What steps am I missing?
Details:
Enabled: Pressure and Shear Force Output under Component Properties > Output.
Assigned surface coordinates but see no force data post-simulation.
Version: Flow3D 11.0.4.
Could this be a version-specific limitation, or is there an additional setting required to extract surface forces?
Mahmood1986 is offline   Reply With Quote
baffle setup, cfd post-processing, flow3d, force calculation, pressure shear forces
Adding surface tension force to Lagrangian particle forces sinhavivekananda318 OpenFOAM Programming & Development 0 May 10, 2024 05:03
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 13:08
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 12:57
