Home > Forums > Software User Forums > FLOW-3D
fluid viscosity in melting of 316L powder
Old   October 15, 2025, 09:05
Question fluid viscosity in melting of 316L powder
hamed
hamedsheikh is on a distinguished road
Hello
I want to simulate selective laser melting (SLM) of 316L powder in Flow-3D Hydro 2023 and for this I entered the fluid viscosity table in Flow-3d Hydro 2023 which is 10^6 in the solid state and about 0.005 in the molten state. But the processing time of the software is very high and is about 1000 days which is not possible to process and analyze. Does anyone have a solution in this regard?
hamedsheikh is offline   Reply With Quote
Old   October 16, 2025, 02:24
Robert
RobAM is on a distinguished road
Are you sure you want to simulate (liquid) steel with a software package designated to water?
Try using FLOW-3D Cast or AM, depending on your specific research field.
RobAM is offline   Reply With Quote
Old   October 21, 2025, 04:00
Question viscosity in Flow-3D
hamed
I do not have access to Flow 3D AM and CAST software, and I only have this software, and in its material section I have defined the properties of 316L steel, but I have a problem with the viscosity section and it gives a very long solution time. Does anyone know how to enter viscosity?
Old   December 5, 2025, 09:40
cast is on a distinguished road
Hi, Unfortunately, you can not solve them in hydro which has different solver than CAST/WELD/AM. I can help you if you share the prepin and supporting files at simulationsinfinite@gmail.com (https://www.youtube.com/@InfiniteSimulations-amv)
cast is offline   Reply With Quote
fluid viscosity, melting
varying the viscosity of the fluid in a Lattice-Boltzmann simulation frioual Main CFD Forum 0 April 29, 2019 06:50
Issue in simulation of open channel flow with high viscosity fluid soleymm1 STAR-CCM+ 2 December 3, 2017 02:44
Fluid turns into solid at given T (via viscosity UDF or solidifcation model?) jpina FLUENT 1 April 3, 2016 04:48
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
