October 2, 2008, 03:28 |
Simulation VIDEO issue in v9.3
I recently upgraded to version 9.3 and I have the following problem:
When I am creating the video of the simulation, I can watch it being created frame by frame, but when I play the .avi file, the simulation starts from an intermediate frame. So, in .avi file I lose the whole process before this frame. Have you noticed it, is there a setting that I have to do, or it is a bug? |
October 2, 2008, 04:31 |
How about using "img2avi"?
Hi, Nikolaos.
I didn't upgrade to version 9.3 yet. But I will do it soon. (I'm using version 9.2.) At once, delete these files. C:\FLOW3D\gui\pref.f3d C:\FLOW3D\gui\flowvurespref.ini C:\FLOW3D\gui\flowvupref.ini If possible, when you make the animation of simulation results, finish the solving and close any other windows(process). Because it required much memory. If you want make the animation of simulation results as you, how about using "img2avi"? It's a freeware. http://workshop.visiongs.de/img2avi/img2avi.zip When you make the animation in FLOW-3D, off the option "delete source bitmap files", and don't make AVI file. Then you can find flame shots of the simulation results as BMP files. Gook luck! |
October 2, 2008, 07:18 |
Re: How about using "img2avi"?
Nikolaos, I believe this is bug with v9.3 as i also experienced the same problem.
Regards CK |
October 2, 2008, 08:47 |
Byongjun Park,
Thank you very much for the hint, I downloaded the software, I will try asap and give my feedback here. CK, I think we are right about the bug, because when I move the flsgrf file to another computer with v9.2 it works fine. So, I am going to post this at the Flow3D official site. Thanks! |
October 2, 2008, 09:10 |
Yes, this is a known problem in the 9.3 release and will be resolved in the upcoming patch. For now, the workaround is to create the bmp images and save them to the disk (from 2d or 3d plots), then open a DOS window and in the directory where the bmp files are run bmp2avi, which is located in the Utilities folder of the 9.2 installation:
> bmp2avi -c msvc -f 15 This will use the MS Video 1 compression and 15 frames per second, which can obviously be changed. Type > bmp2avi -help to see all available options. Michael |
velocity profile export from a simulation onto another | sudhirlv | STAR-CCM+ | 1 | September 12, 2010 18:57 |
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 13:46 |
Overflow problem in steady simulation | ReeKo | CFX | 11 | October 8, 2008 17:57 |
Thermal cycling simulation - FAN issue | Jean-Baptiste | Main CFD Forum | 4 | April 19, 2007 09:02 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
