October 2, 2008, 06:02 |
FSI-Fluid Structure Interaction
I would like to ask for comments about Fluid Structure Interaction in Flow-3D. I need to model the motion of a device which is being induced by fluid around it. I read about GMO Model of Flow-3D.
October 2, 2008, 09:12 |
Re: FSI-Fluid Structure Interaction
The GMO is a rigid body, no deformations. Does it sounds like it will be suitable? What kind of device are you modeling
October 2, 2008, 09:44 |
yes I am not modelling deformation. I only need pressure and velocities in the fluid while the body moves in response to the fluid motion.
October 3, 2008, 10:27 |
Then the GMO model is perfect! you can have also more than one moving body in your domain, and FLOW-3D solves the 6dof free dynamics of all your bodies, coupling it with the fluid.
Fluid Structure Interaction using icoFsiFoam Problems | lr103476 | OpenFOAM Running, Solving & CFD | 79 | August 7, 2014 09:30 |
Fluid Structure Interaction | fw407 | OpenFOAM Running, Solving & CFD | 9 | February 14, 2013 17:25 |
Fluid Structure Interaction and OpenFOAM capabilities | paka | OpenFOAM Running, Solving & CFD | 1 | June 6, 2007 13:56 |
Optimization or fluid structure interaction | Steve_NTUA | Main CFD Forum | 9 | August 29, 2006 03:40 |
Fluid & Structure Interaction... | nesusa | FLUENT | 1 | March 31, 2002 21:30 |
