Home > Forums > Software User Forums > FLOW-3D
Two question about Wave simulation
Old   February 19, 2009, 01:56
Default Two question about Wave simulation
shiw
1.How to simulate irregular wave in Wave Boundary Condition?
2.How to get a wave height data from the computation result
by Flow3D? We can only get "fraction of fluid", "Pressure",
"Fluid velosities",etc,.
Thanks!
Old   February 19, 2009, 10:21
Default Re: Two question about Wave simulation
HC
1. You may need to decompose the incoming irregular wave into several linear waves at the wave boundary, using Fourier transform.
2. You may get the wave height by measuring the fluid elevation/depth. To get fluid elevation/depth, users need to choose the variable in the Selected Data list under the Output panel.
Old   February 20, 2009, 03:23
shiw
As you say, I set a probe at the considering area,then
render the fluid depth from the probe.Then I can get a time
series of water depth.But this data must be done some
statistics to get the wave height at this point.
Please Tell me how do you deal with this data to get a wve
height?
Old   February 20, 2009, 11:07
HC
If you are using v9.3.*, the fluid elevation is computed as the z-coordinate of the topmost fluid element in a vertical column. Fluid depth is computed as the difference between Fluid elevation and the z-coordinate of the bottommost blocked element in a vertical column.
The information can be found in "Help > Contents > MODEL REFERENCE > OVERVIEW > How Do I Model...? > Hydraulics Data".
Old   February 20, 2009, 11:12
HC
Sorry. I understood the question wrong at the beginning. To measure the wave height, you may need to obtain the fluid elevation/height and plot it along the wave direction. That way, you can find the crest and trough in the plot and the difference would be the height.
Wave Simulation solimcfd CFX 48 December 27, 2016 05:26
Wave simulation in CFX solimcfd CFX 21 November 23, 2015 16:06
question about simulation of falling water film mengyue1 FLUENT 2 March 30, 2014 10:16
Water wave simulation anil FLUENT 2 August 25, 2005 08:49
Question concerning about the flow simulation of a fan in an engine room. ghlee Main CFD Forum 3 October 21, 1998 07:05
