Home > Forums > Software User Forums > FLOW-3D
Volume of Flow Rate (VFR) boundary condition
Old   May 23, 2011, 15:19
Default Volume of Flow Rate (VFR) boundary condition
Yang Yue
therockyy is on a distinguished road
Hello experts,
I'm trying to run a simulation with a volume flow rate boundary condition. I use a mesh block to contain a pipe. I know the experimental data of the VFR on one end of the pipe, but I'm not sure how to set the boundary condition of that. Is the liquid generated on the plane of the mesh block the same as the amount entering the pipe?
For example, if the internal radius of the pipe is r, the dimension of the mesh block on the cross-section is a. the volume flow rate of experiment is Ve. Let's see the VFR boundary condition is X. Then which equation below is correct?
X=Ve
or (pi*r^2) / (a^2) = X / Ve
Thanks a lot!!!
Yang
therockyy is offline   Reply With Quote
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 08:20
Boundary condition for exhaut flow with imposed mass flow stephane FLUENT 1 November 24, 2011 03:04
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 19:36
average volume flow rate carno FLUENT 0 April 12, 2007 07:37
Mass flow boundary condition vivian Main CFD Forum 0 April 11, 2006 00:32
