Home > Forums > Software User Forums > FLOW-3D
Marine current turbine (meshing and stimulation help needed!!)
Old   March 16, 2009, 11:48
Default Marine current turbine (meshing and stimulation help needed!!)
oscar
coolyihao is on a distinguished road
1) How to do a good meshing for this turbine I had uploaded? The turbine blade is rotating and the brick region consider as seewater. so, the purpose is to study the flow volume around the turbine only.. Be4 that i use volume meshing to do that but i faced alot of problems such as high skewed element >0.97 and sometimes i got negative volume..
2) Besides that, Im also facing a problem creating a source code of the inlet velocity inside Fluent. At the inlet velocity, i need to create a UDF regarding the pressure. cuz when the depth of seawater increase, pressure increase as well .The formula is P = 101325 + 1000y (y = depth). yet i still dont how to write a source code in this 3D problem..
Thanks
coolyihao is offline   Reply With Quote
meshing a rushton turbine Randheer Yadav FLUENT 5 September 24, 2010 03:12
meshing needed ejazkd FLUENT 0 October 17, 2006 05:02
wind turbine meshing Vyom FLUENT 0 September 28, 2005 12:23
jet stimulation Amit Jain FLUENT 4 May 28, 2005 14:23
