March 27, 2009, 17:25 |
3D bubble model
Rep Power: 17 |
I am working on creating a thermal bubble to simulate an inkjet. So far, 2D model worked OK. However, I couldn't generate a bubble for 3D models. Is Flow3D capable for this purpose? All examples I have are axisymmetric 2D cases. Is there any tip about this?
E. |
March 28, 2009, 00:28 |
Rep Power: 17 |
what did u mean by u couldn't get a 3d thermal bubble?
March 31, 2009, 20:56 |
Rep Power: 17 |
Now, I can model a thermal bubble in 3 D structures. For a bubble jet, I am still curious about what are the proper boundary conditions for the interface between the nozzle mesh and the bottom of the mesh (symmetry ??) which defines a drop path and the drop exit of the mesh (pressure or continuity)?
E. |
April 1, 2009, 11:32 |
MC
Rep Power: 17 |
If there is going to be no affects to the flow from the boundary then symmetry would be fine along the path and I would suggest using a pressure for the exit since it is more realistic.
April 29, 2009, 19:09 |
accommodation coefficient
Rep Power: 17 |
In the bubble model, there is an accommodation coefficient. How can I get it for water vapor on wafer surface? Two models which I saw used 0.05 for this. Is it typical?
E. |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Bubble Number density model | CFDUSERIN | CFX | 1 | November 9, 2011 09:50 |
gas hold up in bubble | Shelly | Main CFD Forum | 0 | November 13, 2006 00:28 |
Query on VOF for Bubble rise | Vamsi | Main CFD Forum | 0 | December 22, 2005 00:02 |
algebraic slip model with stirred suspension? | Manuel Krause | CFX | 0 | April 15, 2005 09:10 |
