9.4 version...is it possible to analyse the output of a 9.3 simulation?? |
February 9, 2010, 06:56 |
Hello users, I wonder to know if it is possible to analyse a simulation made with the 9.3, or older version of Flow3D, using the 9.4 without running again the simulation...
February 9, 2010, 11:08 |
It should be possible, sdr...have you tried and it failed?
February 9, 2010, 11:22 |
yes, I try and I get a message which says "Failed to process guipost"...
Can you help me? |
February 9, 2010, 11:33 |
Hmm...I just tried and it worked fine. Have you tried contacting FLOW-3D support?
February 10, 2010, 09:39 |
michael barkhudarov
Rep Power: 18 |
See if you can run the 9.4 post-processor from the command line:
runpost <flsgrf file extension> If it still does not work, send the error message that you get from this operation. |
February 11, 2010, 09:46 |
thank you Michael...I will let you know...
February 12, 2010, 04:57 |
it's ok now...the problem was in the check of the license using the network...just a connection problem Everything is fine now...
Thank you |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
esqr - definition changed from version 9.2 to 9.3? | Andreas | FLOW-3D | 1 | February 8, 2009 23:23 |
Output power from simulation | JSM | FLUENT | 0 | November 27, 2008 06:04 |
MFX output of simulation time | Richard | CFX | 0 | October 10, 2008 09:50 |
Output Excel File in Transient Simulation | Soon | CFX | 5 | July 11, 2005 06:11 |
