Home > Forums > Software User Forums > FLOW-3D
How to estimate time to complete simulation.
Old   May 4, 2010, 14:25
Default How to estimate time to complete simulation.
Frank D.
frankyd is on a distinguished road
Is there a way to estimate how long Flow-3D will take to run?
Items that are always the same include ...
Linux OS, 4 Gb ram
Quad core machine. (set OMP_NUM_THREADS="4")
Items that vary ...
Number of time steps
Number of cells in X, Y, and Z
My assumptions are ...
1.) Doubleing the number of time steps should double the run time.
2.) Double the cells in X, Y and Z and it should take 2^3 or 8 times longer.
It seems like my second assumption is terribly incorrect.
Thanks,
Frank D.
frankyd is offline   Reply With Quote
Old   May 5, 2010, 00:02
michael barkhudarov
MuxaB is on a distinguished road
this is all very approximate, but typically, if the time step is controlled by convection, i.e, dx/U, then doubling the number of cells in all three directions will increase the run time by 2x2x2x2=16 times since the time step will also be cut in half.
If you have transient free surface then it makes the estimate more complicated because the time step can vary a lot during simulation due to the wave movement and splashing, plus the domain occupied with fluid (as opposed to void) and hence the amount of computational work may also vary with time.
MuxaB is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Time step for combustion simulation AdidaKK CFX 11 December 3, 2009 11:47
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
