Home > Forums > Software User Forums > FLOW-3D
Wind Tunnel
Old   August 19, 2010, 06:35
Default Wind Tunnel
freddie espinosa
kaje is on a distinguished road
Hi all,
How to make a wind tunnel?
i want to simulate a rotating blade..
please advise..
Thank you in advance for your help
kaje is offline   Reply With Quote
Old   August 27, 2010, 00:04
michael barkhudarov
MuxaB is on a distinguished road
There are a couple of models available for a rotating blade. The GMO model can give you a very detailed solution, but may be slow, especially if you are modeling many revolutions. In that case, you can use the fan/impeller model which averages the effect of the blades over the volume they cover in space and applies an momentum source to the fluid rather than a boundary condition from a moving GMO. This is a very efficient model for modeling many revolutions of an impeller. The model can be refined by including the effects of blades.
The details of each option are in the manual.
MuxaB is offline   Reply With Quote
wind tunnel results vs fluent pixie Main CFD Forum 1 August 20, 2009 08:02
how to consider perforated wind tunnel wall in CFD simulation littlelz CFX 4 June 11, 2009 05:51
Simulating a Göttingen type wind tunnel in FLUENT Chris FLUENT 3 December 4, 2006 17:33
Virtual Wind Tunnel in FLUENT ND FLUENT 0 April 7, 2006 07:43
Wind tunnel modeling Pandu CFX 3 May 19, 2003 21:49
