November 4, 2010, 15:21 |
Void Array Index Warning
Joey
Rep Power: 15 |
I'm trying to run a casting simulation but keep getting this message in the warnings and errors...
warning: void array index exceeds maximum nvor = 28467 at cycle = 12938, time = 0.20113E+01 void region volumes and pressures may be incorrect I have noticed that my fluid volumes are really off in my casting, anyone know why this happens and what to do to alleviate it? |
November 4, 2010, 23:54 |
michael barkhudarov
Rep Power: 17 |
It looks like it is going unstable. Can you look at the results? Does the flow look reasonable?
what version are you running? By itself this message is not critical, just telling you that it cannot keep track of all voidss in the domain and will join some of them to stay within the maximum allowed number of voids. But the fact that you have so many of them is an indication of a severe breakup of the fluid. |
November 5, 2010, 10:11 |
Joey
Rep Power: 15 |
I can look at the results, they look reasonable flow wise, but the volumes I'm getting are way off for filling. I'm running version 9.4.1.
November 6, 2010, 20:39 |
#4 | |
michael barkhudarov
Rep Power: 17 |
What kind of filling problem is it? high-pressure die casting, gravity? |
November 8, 2010, 16:16 |
Joey
Rep Power: 15 |
It is a gravity casting, the flow PATTERN looks fine, but I used force windows to measure the volume in each cavity of my mold, and the volumes that the windows are showing are not at all what they should be. Basically, the graphics are showing the cavities full, but after calculating the volume of each cavity and comparing it to what the force window says it is, they dont matchup at all. I was wondering if that error had something to do with it.
November 8, 2010, 23:13 |
#6 | |
michael barkhudarov
Rep Power: 17 |
November 9, 2010, 11:09 |
Joey
Rep Power: 15 |
I'm getting extra volume residing above the cavities after they fill. I tried to measure and match the fluid volume at the beginning (using the preprocessor and the "report" message "fluid at time zero") to the volume of the cavities, but even after doing that I'm getting extra slop on top after the simulation has completed.
November 15, 2010, 13:31 |
#8 | |
michael barkhudarov
Rep Power: 17 |
The second reason is that not all cells m ay be100% full. If the F-packer is on (default), then most cells should be at least 99% full. However, some may have much less fluid, e.g., the last cells in the cavity to fill. The f-packer tries to 'pack' them but it takes some time during which fluid can spill. Another possible reason is the open area at the inlet is not what you think it is. The pre-processor reports open areas at mesh boundaries in prpout. |
Display Modes | |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 07:59 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
