April 8, 2010, 05:52 |
How to set the parameters?
邱鑫
Rep Power: 15 |
When I simulate the arogn fluid through the porous media.However,I don't know how to set the viscous inertial resistance factor and the inertial resisitance factor.Thank you for help!
April 10, 2010, 14:18 |
Yang Yue
Rep Power: 16 |
November 22, 2010, 23:53 |
Oky Andytya
Rep Power: 15 |
November 30, 2010, 00:58 |
michael barkhudarov
Rep Power: 17 |
flow resistance in porous media is define in FLOW-3D by drag coefficient K:
du/dt=...-K*u Where the expression for K depends on the choice of the drag model. The most commonly used is the Reynolds number dependent drag, IDRG=4, which requires a linear and quadratic flow loss coefficients. The Manual gas more details on choosing those. |
December 23, 2010, 02:50 |
Oky Andytya
Rep Power: 15 |
Hi all,
How to modeling porous medium in fluent, if it's heated from below. If I have a rectangular channel and fitted porous medium with the porosity is 15%. |
February 1, 2011, 21:59 |
Oky Andytya
Rep Power: 15 |
Hi everyone,
I'm trying simulation porous media in rectangular channel, but the result isn't suitable with any research. So, would you help me. I wish someone can check my simulation and give some reports if there is something wrong. Thank you for your help. Please send your e-mail, than i will send you my works to to your email. my e-mail: oky.andytya.net@gmail.com Regrads, OKY Andytya P note: I use ANSYS Fluent 6.3 [CFD] |
February 3, 2011, 10:26 |
private
Rep Power: 17 |
You might consider posting this request in the 'Fluent' discussions'.
parameters |
Display Modes | |
How to set a initial temperature and constant heat flux at same BC's?? | Jane | FLUENT | 4 | October 25, 2015 13:01 |
How to set a oblique incidence wave Boundary | shiw | FLOW-3D | 2 | March 6, 2011 20:15 |
Problem in installation of OpenFOAM | sachin | OpenFOAM Installation | 7 | January 22, 2008 02:40 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 14:29 |
Problems with installation | jonititan | OpenFOAM Installation | 4 | November 6, 2005 05:16 |
