February 16, 2012, 20:27 |
Measuring fluid depth
half rho vsquared
Rep Power: 14 |
How do I measure the depth of fluid at a specific location in a draining channel or tank? I want to measure fluid height along one line, just like a dipstick or float gauge would.
February 17, 2012, 10:19 |
half rho vsquared
Rep Power: 14 |
Ok, found it. For future reference for someone:
Model Setup - Output - Special Output - Hydraulic Data Only works with free surface flows and z must be set up with positive in the vertical direction. |
February 17, 2012, 11:16 |
MC
Rep Power: 17 |
History probes can be added before you run the simulation.
Depending on your version you will either have to enter them manually into the prepin file or through the GUI meshing & geometry. You also have options in post-processing in 1-D and text output tab. |
February 17, 2012, 15:46 |
half rho vsquared
Rep Power: 14 |
Good info, thank you!
Display Modes | |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Specifying fluid density | sanjibdsharma | OpenFOAM | 2 | February 22, 2011 09:55 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 10:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
fluid hot volume in fluid cold volume | zahid | FLUENT | 4 | June 1, 2002 10:11 |
