June 15, 2013, 06:35 |
No fluid in open channel flow VOF
FHydro
Rep Power: 13 |
hello
I am modeling a open channel flow in fluent with using open channel BC. I don't know every time i am using that BC in simulating, there is no fluid into the modeling zone after steady simulation. I am defining reference pressure in 0,0,0 coordinates and in other levels but it don't works. What is reference level in defining free surface and bottom of channel in BC? may be i am defining incorrect that? My BC in inlet is pressure inlet with inlet ID =1 for air and water (together) and outlet is pressure outlet with gauge pressure=0 thanks |
June 30, 2013, 19:28 |
Hossein
Rep Power: 15 |
To simulate a flow surface model, you have to use the VOF model.
then you have to patch the water in your model, to define the level of water. your BCs seem fine, but you have to define your model in detail
Hossein Amini PhD student in Biochemical Engineering; Computational Science and Engineering department; North Carolina Agricultural and Technical State University |
July 2, 2013, 02:05 |
FHydro
Rep Power: 13 |
When i am marking water height in inlet boundary with inside option, 0 cells marked and with outside option, all my model cells going to mark!!!!?????
Display Modes | |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 12:03 |
Yacht in Open Channel Flow | andreimour | FLUENT | 1 | October 15, 2010 00:54 |
Open channel flow | Mehdi Moayeri | FLUENT | 0 | August 26, 2008 11:55 |
open channel flow vof model | Yong | Siemens | 3 | June 21, 2005 06:54 |
