June 3, 2013, 13:02 |
Discrete phase
nader
Rep Power: 12 |
I'm grateful I have a question, please answer
I'm working on discrete phase model. gas is Discrete phase and water is continuous phase. I'll solve the continuous phase firstly, gas is single phase, of course, to say model is two-dimensional flow in a curved channel. After that it'll be a discrete phase gas injection. All the other options for the definition of the turbulent energy. but the answer change when h click track for search of track. once question:How do I tell Fluent steady state for this model? my Fluent software have not unstable or steady state option Very happy to answer any one |
June 3, 2013, 15:36 |
OJ
Rep Power: 19 |
I do not understand your question quite precisely, however, be assured that the default method of solving in FLUENT is steady state. You have to explicitly specify if you want transient solution, if you believe your flow is unsteady.
OJ |
June 3, 2013, 16:14 |
Question Correction
nader
Rep Power: 12 |
thank my friend.
i want steady flow but the answer is unsteady, and when i click track, the answer for particles path is different , means answer change with click, why? the process my work: solve continue phase solver: segregate steady k-e model implicit disperse phase model DRW method create injection for disperse phase click track Last edited by del; June 4, 2013 at 17:24. |
June 6, 2013, 07:17 |
OJ
Rep Power: 19 |
Probably the solution is not converged yet for continuous phase. Have you enabled "interaction" between the two phases? If you have, then you need to have converged solution after taking into account the interfacial interactions, ie, you have to run it furter until it is converged.
If you keep getting dancing residuals, then perhaps it's a transient case. OJ |
June 18, 2013, 18:02 |
#5 | |
nader
Rep Power: 12 |
Hi my friend. the solution for continuous phase is converged. I solve equations for continuous phase first and solution is converged. "interaction" between the two phases is enable in the discrete phase dialog box. can you write for me stage of modeling discrete phase(water) and continuous phase(gas)?, maybe i understand my mistake thank |
June 19, 2013, 04:55 |
OJ
Rep Power: 19 |
Have you done the tutorial? It covers the procedure. There is a lot of help in the documentation.
OJ |
Display Modes | |
Discrete Phase Model | vittal | FLUENT | 4 | October 28, 2014 11:07 |
Discrete Phase Modeling (Pipe erosion) in OF 2.1.0 | mecbe2002 | OpenFOAM | 3 | February 2, 2012 02:17 |
continuous and discrete phase coupling in fluids-HELP | atmcfd | Main CFD Forum | 1 | December 31, 2009 00:02 |
uncoupled discrete phase calculations | AMV | FLUENT | 0 | December 3, 2003 08:21 |
Discrete Phase Modeling | Fred Kang | FLUENT | 3 | October 18, 2000 11:23 |
