May 31, 2013, 11:16 |
Interface
Mahboobe Mahdavi
Rep Power: 13 |
Does any one know how to How to define velocity for the fluid in an interface between a solid and fluid part?I am going to model evaporation so I have solid wall adjacent to vapor chamber , so the input heat will result in vapor arise so it will have a velocity. I have to define one of the lines in the interface as a velocity inlet. But fluent wont let me to do this if I use form new part to connect my parts. In case that I am not forming the new part I will have problem with the threads in the udf! I can explain more in case that you are interested.
September 18, 2013, 09:23 |
#2 | |
Mohammad Bahreini
Rep Power: 13 |
what is youre case ? do you want simulate vapor chamber(that use for cooling CPU &....) or traditional heat pipe( with wick).can you explain more? |
September 18, 2013, 09:49 |
Mahboobe Mahdavi
Rep Power: 13 |
Thanks for your attention , its for traditional heat pipe, I have already solved the problem. I split the spaces so its not defined as interface in fluent and I can choose velocity inlet boundary condition
September 18, 2013, 10:25 |
#4 | |
Mohammad Bahreini
Rep Power: 13 |
Thank you for Reply i worked about pulsating heat pipe (without wick) last.but now,I want simulate traditional heat pipe (that have wick).and i have some question?can i have youre mail or send PM for you? |
Display Modes | |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
