Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Cfd of water-air flow in ejector in fluent
Old   October 13, 2013, 13:05
Default Cfd of water-air flow in ejector in fluent
ARI
ARI7862 is on a distinguished road
I am a postgraduate student and am struggling very badly to get a converged solution through pressure inlet- pressure outlet B.C.
I am trying to simulate the horizontal flow of water (primary phase) and air (secondary phase) in an ejector. My geometry has two inlets (inlet 1: through which high pressure water is supplied, inlet 2: through which air at atmospheric pressure is entrained) and 1 outlet, which is open to atmosphere. I am doing a 2d axi-symmetric, steady state simulation in FLUENT.
B.C are as follows:
Inlet 1: velocity inlet (water velocity 2m/s, air velocity=0, air volume fraction=0)
Inlet 2: pressure inlet (gauge pressure of mixture=0 pascal, volume fraction of air=1)
outlet: pressure outlet (gauge pressure of mixture=0 pascal)
I am using pressure based solver, algebric slip mixture model, standard k-e turbulence model with standard wall functions and 5% turbulence, pressure-velocity coupling SIMPLE and URF's of pressure, momentum are 0.2 and for slip, vol. fraction,TKE, TDR =0.1.
i am using a structured mesh with 53000 nodes having minimum orthogonal quality of 0.77 and max. aspect ratio of 4.9.
I am facing convergence problem. my solution is diverging. please help me out in solving this problem with pressure inlet (air) and outlet B.C's.
CFD experts please help me, its very urgent:
reply me at:
sonawatarihant@gmail.com.
Thanx in advance...
ARI7862 is offline   Reply With Quote
2 phase flow, 2d axisymmetric., ejector, fluent13, water-air
introduce air to water flow masoudarami FLOW-3D 10 September 13, 2016 09:15
Coupled DPM water spray inside enclosed volume of air dan86 FLUENT 0 July 19, 2013 11:23
CFD for air flow analysis in a room bidalufias Main CFD Forum 1 May 12, 2011 19:11
Simulation of steam (CO2 and Water vapor mixture) flow through nozzle using Fluent. Jimmy FLUENT 0 March 2, 2011 12:30
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
