Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
two-phase flow with a single phase simulation
Old   October 28, 2013, 02:42
Question two-phase flow with a single phase simulation
Lawrence
caunima is on a distinguished road
Hello everyone,
I tried to do a simulation of heat pipe which exposed to a hot air at the heat pipe external wall. The flow inside the heat pipe is a two-phase flow condition (water-vapour) and the heat pipe external surface is a single phase flow (only expose to air)
I used VOF model +UDF, set vapour as primary fluid, set water and air as secondary fluids. Before the simulation begins, I patched the heat pipe external volume with air and water inside the heat pipe.
I noticed that external volume truned back to vapour phase after the simulation completed.
I wish to know how do you setup this kind scenario in FLUENT? Thank you.
Regards
Lawrence
caunima is offline   Reply With Quote
multi phase, single phase, vof model
PEM fuel cell simulation pchoopanya Mesh Generation & Pre-Processing 1 February 29, 2016 23:56
Divergence after change in mass flow rate in two phase flow meetsunilkale FLUENT 1 March 25, 2013 03:03
low speed compressible two phase flow?? cat CFX 0 November 15, 2005 07:59
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
Two-phase/ Single phase mix flow Reza Main CFD Forum 1 August 6, 2003 06:36
