Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
divergence after patch
Old   October 31, 2013, 14:39
Question divergence after patch
mehdimoradi
mehdimoradi. is on a distinguished road
Hello
I have been performed a multiphase simulation using eulerian option. Primary phase is air and secondary phase is grain. in begining of simulation i patched volume fraction of granular phase as 0.5.
solution was diverged: Error: Divergence detected in AMG solver: pressure correctio. Error object:#f.
then for solving i removed the patching process. solution was converged.
what idea is proposed to convergence happened in patching option??
Any help would be thankful.
mehdimoradi. is offline   Reply With Quote
Old   November 3, 2013, 04:30
bahare
bahare is on a distinguished road
hi
iits better to reduce relaxation factor of momentum andd pressure
bahare is offline   Reply With Quote
Old   November 3, 2013, 07:27
mehdimoradi
Originally Posted by bahare View Post
hi
Hello
Thanks for your answer;
These factors were reduced to 0.1 or lower. but the problem was diverged.
please any suggestion??
Old   November 3, 2013, 07:30
mehdimoradi
hi
Hello
These factors were reduced to 0.1 or lower. but problem diverged.
any suggestion??
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
