Moving a trimtab at the water's edge (free surface)
3D schematic model showed in pic
help me to Descripted Bonudary Conditions and meshing model. I thank you ahead for your help. http://www.uplooder.net/img/image/75...f8/project.bmp |
u can break B.C 2 and B.C 4 in to two boundaries while define them in Gambit. So u can handle better while air and water are separated. Then for water u can choose mass flow inlet and out flow, and for air u can choose both of them pressure outlet in the left and right side.
I'm here for more comments of others. TNX |
This pic showed my model whitout mesh.
but http://www.uplooder.net/img/image/37.../Untitled1.png The model meshed showed in pic. Mesh around an obstacle with a high density that quad/tri used for mesh surface. and other surface used quad(map). Is it OK? what is mesh model better? http://www.uplooder.net/img/image/44...4f5d9/1234.png |
