April 9, 2014, 18:34 |
need help for designing slug flow in tube
HARIGANESH
hi everyone
I am trying to design a slug flow in t shaped tube of width 0.5mm suface thicknes of 0.5 mm with two inlet i used 2d pressure passed , transient , absolute , planar multiphase model - Volume of fluid material = air -primary phase , water- secondary phase suface tension 0.07 BC inlet1 - air mass flow inlet of .23 kg/s inlet 2 - water mass flow inlet of .23 kg/s wall surface-body = wall adhesion angle of contact is 90 outlet is pressure outlet solution method is piso solution initialization is standard , computed from inlet 2 area patched is showed in d below diagram run calculation time step size is 1e-08 number of time step is 300 i am able to see the flow or but not the slug flow plz help me |
Flow over single tube | monoposto | FLUENT | 0 | November 19, 2012 19:47 |
Flow Through Bend tube of circular c/s | applemango | FLUENT | 0 | March 8, 2010 05:52 |
Flow blowing through a hollow tube | pomelo | Main CFD Forum | 2 | October 13, 2009 10:11 |
Flow around the microscale tube in CFX4.4 | hsinluen | CFX | 2 | December 10, 2003 21:53 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
