April 28, 2014, 19:26 |
Particle ignition problems
Joakim M. Johansen
Rep Power: 13 |
Dear forum,
I am modeling particle combustion in power stations, swirl stabilized suspensionfiring. But I am having trouble establishing particle ignition. My approach has (roughly) been:
But this is where I run into problems. When I run the single iteration with the particles, the domain cools down below devolatilization temperature, and the process stops. Any tips or tricks are welcome. I am using species transport with the eddy-dissipitation mech. Devolatilization rate set to single first order, with default kinetics. In the ieger to obtain ignition, I have underestimated the particle diameter. Best regards, Joakim |
biomass, combustion, dpm, ignition, multiphase |
DPM particle time step | amos | FLUENT | 1 | January 4, 2020 08:46 |
droplet separation off a particle in turbulent stream | anonymous_89 | Main CFD Forum | 0 | August 22, 2013 13:40 |
Particle Tracking for ion | Jun | CFX | 2 | August 31, 2010 08:19 |
Particle Trajectory calculation | yueroo | FLUENT | 2 | July 13, 2009 13:32 |
Particle Trajectory calculation when particle hit | yueroo | FLUENT | 2 | February 28, 2001 04:26 |
