small particles incomplete with Runge-Kutta scheme |
May 9, 2016, 11:12 |
souria
Rep Power: 13 |
Hey everyone,
Another post to get some explainations on my case ! When I track small particles using Runge-Kutta or Trapeze scheme, I get all my particles incomplete! But, when I try with implicit or combination of implicit and Runge-Kutta it works (no particle is incomplete) Any explanation, please ? Thanks Souria |
May 16, 2016, 12:47 |
particles
Rep Power: 9 |
Hi souma,
i didn't understand well your question because i m beginner in that,but i guess that you can help me if you don't mind .i'm student in second year master degree ,i use fluent.16 for simulation of fluidized bed uses the pomace like particles (without combustion or any chemical reaction ),i m trying to understund at first the models that fluent use.and i think that i need the udf for determine the combustible (pomace)characteristics,someone told me that i will use ranj kutta ,can you help me to write this program please or give me some ideas to write it thank you for any help |
May 18, 2016, 05:17 |
#3 | |
souria
Rep Power: 13 |
Good luck Souria |
May 18, 2016, 11:20 |
fluidized bed
Rep Power: 9 |
Hi souria ,
thanks for your response yes i m trying to understand because i m beginner in this,sorry my english is so bad if you don't mind i will ask you again in my final projecti should I have to determine the point of optimal fluidization operation (the necessary air speed and particles), I work on a biomass boiler, I draw the geometry and I did the mesh (there is not chemical reactions or combustion in the beginning, there is just fluidization), but regarding the models I found difficulties ,there are several choices and more bars, I am dispersed ,if you can help me I will be appreciated souria, guide me please. |
Runge Kutta 4th Order Source Code | sugu | Main CFD Forum | 4 | October 26, 2012 03:15 |
Multiphase flows (oil with small particles) | sami_lakka | OpenFOAM | 1 | January 10, 2010 17:35 |
brownian motion of small particles | mazdak | Main CFD Forum | 1 | November 2, 2009 19:54 |
Could small size particles be treated as gas? | Nanazhu | FLUENT | 0 | July 20, 2008 23:44 |
Could small size particles be treated as gas? | Nanazhu | Main CFD Forum | 0 | July 20, 2008 23:43 |
