phase change with multiphase flow in porous media
Hello everyone,
I'm presently on a problem I really don't know how to face with fluent : I'm working on the dissociation of a solid into gas + liquid (water and methane) inside a porous media (sand) filled with a liquid (water). I think I reviewed most of the possibilities for multiphase flow solutions proposed by ANSYS FLUENT but could not find something which can manage this phase change. Does someone know what I could do ? Can I still plan doing it using FLUENT (if you have a tutorial on a resembling problem I would be very glad) or should I use an other software/code ? Your help would be very helpful ! Thanks in advance :) |
I am working on a similar problem. Have you found a solution by now and is it possible to solve the problem with Fluent? Best regards Max |
