December 12, 2014, 02:48 |
wall adhesion and surface tension
Rep Power: 11 |
Hi everybody.
I am simulating a water wheel at low rotational speed (1 rad/s). It is multiphase since it is in an open channel flow. I want to know the torque. 1) I have set 0.07 N/m the surface tension; it is right? 2) Have I also to click on wall adhesion? It is important? 3) There is a way to have in output a file with the time history of the torque (or the moment coefficient)? Because in output Fluent gives me only a file with the torque at the last time step and not its history during the whole simulation. Thanks |
open channel flow, torque coefficient, turbine, wall adhesion, water wheel |
VOF with surface tension and wall adhesion | Agad15 | Fluent Multiphase | 4 | December 20, 2016 17:07 |
VOF +surface tension force modeling+ open channel flow+cyclic region= fatal error? | SJSW | Fluent Multiphase | 2 | November 18, 2014 04:15 |
Surface tension problem in CFX | lefuliang | CFX | 6 | August 29, 2013 05:49 |
Problem with wall adhesion | MachZero | Main CFD Forum | 2 | July 2, 2013 09:50 |
